46callaway
I was doing some datalogging today and my car hit the rev limiter on the 1-2 shift. Right after that I got a CEL P0320. I tried to clear it with Sniper but it keeps coming back. Cam Position Sensor or Crank Position Sensor? I found this info online:
P0320 - Ignition Engine Speed Input Circuit Malfunction The ignition engine speed sensor input signal to PCM is continuously monitored. The test fails when the signal indicates that two successive erratic profile ignition pickup (PIP) pulses have occurred.
* Loose wires/ connectors.
* Arcing secondary ignition components (coil, wires and plugs)
* On board transmitter (2-way radio)
The DTC indicates that two successive erratic PIP pulses occurred.
