46callaway
So I decided it's time to get serious and get the Cobra intake manifold and the MMR IMRC deletes along with an Aeromotive FPR. My question is will the Aeromotive FPR fit on the Mark VIII rail with the Cobra intake installed?
You only have one fuel pressure regulator.Thanks Jeremi! Also, I noticed my 98 fuel rail looks like it has two fuel pressure regulators, the 96 cobra rails only have one... will this cause any problems, CEL light etc., when I swap the rails?
It's called a "Fuel Pulse Damper". On the Cobra it's in the feed line before the rail.As JP said, there is only one regulator. The other "thing" (still don't know what to call it)is there to equilize the pressure throughout the fuel rail, and if it's not there on the cobra rail, then it's not needed for that design of the rail. Delete all those vac lines, and you won't have a problem. EGR and AIR should go too
That line looks to be too long, they need to be short, like 30" or something close. Get out the tape measure and find out. All the stock lines I've seen were too long, maybe tbird lines would fit ? But why would you want tbird parts on your car ?
Buy the russell parts and get over it.
