ryanharrington
anyway to trip the solenoids and deflate the front bags?
Why?anyway to trip the solenoids and deflate the front bags?
Ditto here...I reused the old ones and got burned. The rear kept deflating down over the weekend (when not in use).You will definitely need new "O" rings based on my experience. The old rings dry out over time and will not seal when re-installed. Again, make sure you lube up the new ones on install as above. Local stores and dealer should also have, although I would order from Eddie if I had the time as "he is the man".
