hey i need help with my air ride from someone, what are the most common problems the like a 1996 mark viii air ride, the compressor kicks in for like two seconds then just makes little quiet noises and the front is just sittin on the ground..HELP!
Hi Jake. Welcome.
Check out the website Driller posted above. It's great for troubleshooting. At first glance, it sounds like you might have a compressor or wire contact problem.
Start a new post in the Suspension section, you'll get more direct responses about your problem, a lot of us have had some of the same troubles.
For dfoster's door latch problem, make sure that you spray the latches on both doors.
I spent an hour cleaning and spraying the driver's door latch, only to find out that one spray on the other door fixed it.
