Out of the car they are, but then to get them to work some good welding will be needed.Damn I was hoping long tubes would be a direct fit lol
What is a labor charge?It is going to be AT LEAST a "wash" either way. The Kooks will drop in with a labor charge, or you can get the Cobra longtubes for cheaper right off the bat but pay extra labor to have them modified to fit. I have 96-98 Cobra BBK longtubes on my car and THREE primaries on the driver's side header had to be cut out and re-routed/welded. The outputs for the 02 sensors point to the inside and hit the trans, so they have to be capped and re-tapped to output to the outside. The collector flange on the passenger header had to be clocked about 45 degrees or so and re-welded to the header to clear the trans pan on that side and it still hugs tight to the pan. The collector on the driver's side header hits the floorpan (with good motor mounts that are not worn in) so we creatively pushed up the floor in that area creating a small dent. ( because racecar)
The custom exhaust shop royally effed my driver's header up and my buddy re-did the job on that header for about $500. Ballpark estimate would be $1500 worth of labor from an exhaust shop who knows what the heck they are doing. Plus the cost of the headers. So about $2000
Your results may vary.......
From what i have heard on a stock motor 7-13 ponies.What are the HP gains with headers ?
Powerrrrrrrrrrr.Why soooo loooooooooong?
Because RACE CAR. Or whatever the kids say these days on the line. LOL.Why soooo loooooooooong?
Dare I say..... SIDE PIPES!
