Found the brake fluid leak
jbuch
[link:www.lincolnsclub.org/dcforum/DCForumID5/46.html|The original post]
Once I got the front wheel and fender cover off, it was easy to see what was leaking.
Zoomed out
http://mywebpages.comcast.net/jeff82x/brake-leak-2003-05-03-01.jpg
Close up
http://mywebpages.comcast.net/jeff82x/brake-leak-2003-05-03-02.jpg
http://mywebpages.comcast.net/jeff82x/brake-leak-2003-05-03-03.jpg
After wiping some of the crud off
http://mywebpages.comcast.net/jeff82x/brake-leak-2003-05-03-04.jpg
According to the service manual cd, the part is the 'Brake Pressure Control Valve.' On Ford Parts Network, I saw a part listed as a 'Pressure Metering Valve' listed in the brakes section. If that is the part, it's gonna set me back $125.
Does anybody know if this part is fixable? The inlet and outlet nuts were tight, and the brake line appeared to be fine. I am going to go take a closer look, and I'll post more pictures if I find anything more.
LOLINC
Looks just like what I have going on. I was thinking a leaking line or brake power booster.
You may have steered me in the right direction.
I first noticed the paint peeling but never saw fluid.
It now puddles in the same manner.
SMOOTH8
SMOOTH8 Its a pressure control valve for rear brakes, part #2B091, not repairable unless you know the relief settings and have a test bench
