7 sek mark
i have a full EBC front brake set up on the front of my car with the EBC dimpled and slotted rotors and the EBC greenstuff pads. i did notice a improvement in braking over stock when i put them on the only down side until now was a little noise. it sounds kinda like i stuck playing cards in my wheels but its not that bad. now on to the problem and the whole reason i put these rotors on my car was because my stock rotors were heat cracking. i noticed these rotors are now doing the same thing i still have just under 1/2 of the pad left but if i lay into the brakes for any time it feels like the front end is about to fall off the car from the vibes.
so has anyone found a good set of stock size rotors for the marks that will not heat up and warp or crack under hard use? i thought that by going with a good name brand rotor i would be getting a good set of brakes.
