Front Wheel HUB torque specs
Stone17
What Is The Torque Specs For The Front Wheel Hub Assembly Nut?
Need the help ASAP.
Is 258 ft. Lbs the right spec.
DLF
From the Lincoln Service Manual:
Front Axle Wheel Hub Retainer 255-345 Nm 188-254 Lb-Ft
The 'old post' from the 'old man' was quoting direct from the 'old factory manual'. :p
251 lb-ft is the spec. You're gonna need a bigger torque wrench.
You can usually rent one for a nominal fee from a parts store though it may require a CC deposit. Not too many people own a torque wrench big enough for the job. I myself simply borrow one from work.
Sapperfire
what pieces are you needing.. i found another blue/blue in a local yard, most interior looks good, seats are cracking like mine.. which is why i have seat covers until i get my sewing machin fixed, oh ..and ill be taking the top dash piece as well as the driver door panel, all other is up for grabs
-maybe we should make another thread.. in the interior section?-
