BlackMark8
What is the fuel pressure on a stock 1997 lsc ? At the fuel rail. - I mean what is it "supposed" to be at from the factory
Minimum 39 psi WOT @ full load. It is the same as the fuel pressure at the fuel rail with the vacuum disconnected from the fuel pressure regulator.I am adjusting my nitrous setup and i need to know what it usually is at the fuel rail (the schrader valve) 28-45 is not an acceptable number, i need to know what it is at full throttle because i need the right fuel pill for my fogger.
Driller ?
The fuel pressure regulator is a differential pressure device. Fuel pressure is regulated to a constant differential pressure compared to manifold pressure. Since under normal driving(including WOT) the absolute manifold pressure varies, for the fuel delivery to remain a constant, the fuel pressure is varied according to the manifold pressure(even if you use boost).Fuel pressure regulator hose disconnected? what about it when it IS connected? since it will be all the time when im racing.... :/
Well, considering you asked for "fuel pressure" but weren't very specific on how you asked it, then I gave you an answer based on the information you provided, and in response....you give me this response like I knew wtf you needed.And J, you seem very cocky in your responses. From what i observed from your other posts you kind of seem like an a**hole.
Now you're calling me out? How about I bring my 13 second M8 down there.........You can bring that honda down to FL anytime you want and see how it runs against my car "that i should not drive".
None taken......I'm far from an a$$hole and you'd see that. I joke from time to time, but other times I provide serious answers. Also...I make very good use of the "smileys" so everyone reading knows I'm not serious and knows the emotional tone of the reply.No offense, and thanks for your help, but id rather not use your advice
