WTB: Gen II parts
SCTBIRD1173
Mark my Bird!
Still in need of a couple of misc items for my 98 LSC.
LH lower seat trim (prefer midnight black but I'll take ANY color)
"Leather" case for owners manual
Drivers door (black preferred)
Trunk sill trim (by the latch)
Cup holder assembly
Mint steering wheel
Bezel around headlight/dimmer switch
Bezel around ignition lock cylinder
That's all I can think of at the moment. I'll update the list as necessary.
I'll be at Carlisle ;)
Thanks!
Mark8Murder
Cup holder assembly
Mint steering wheel
Thanks!
I have a complete ivory center console with a working cup holder assembly
Also have a gray bezel around the headlight dimmer switch
SCTBIRD1173
Mark my Bird!
OK, PM me with a price for the cup holder assembly, I was thinking I can just take it apart and use what I need. The cup holders themselves are always black/charcoal right?
I'm guessing a gray bezel wouldn't work for me huh? I want to replace mine because it's scratched. Would I need to get one only from a 98 with Midnight Black interior?
Thanks a lot!
98mark8lsc
I make stuff
If you're willing to try cupholder surgery, I've got tons of cupholder parts, and probably exactly what you need. Or, if you PM me a good offer, I may consider giving up one of my midnight black cupholder assemblies...
SCTBIRD1173
Mark my Bird!
I'm definitely willing to try cup holder surgery :D
It's only my RH cup holder arm that broken, it doesn't look that bad to change just the arm... :wink:
Thanks man!
Mike P
c:enter
Staff member
do you have an extra passenger side cup holder wing? I need one still
Yes please Mike, for some reason my car didn't come with one :(
pm me your address and I will get it to you, just cover shipping after I find out how much it is
SCTBIRD1173
Mark my Bird!
Thought I could edit my first post to update the list but I couldn't figure it out...
I'm also looking for the piece of interior trim opposite the side mirrors. I need both left and right sides. Seems these break kinda easy if you don't know what you are doing... :eek:
DLF
I have the driver's side....
SCTBIRD1173
Mark my Bird!
Yep, I think they are all black?
And most all break at the same place when you remove them. :D
Yeah, black/charcoal gray...
Thanks Driller! I don't feel as bad now... :D Is there a trick to removing them? I thought I learned from the breaking the drivers side but even though the passenger side came off w/out breaking it still got damaged. :(
If you look at the backside, you will see a latch hook which must be depressed to release before prying the trim piece loose. Problem is if you don't know where the latch is and pry, it will break. Or you push to hard on the latch with the trim removal tool and break the latch.
SCTBIRD1173
Mark my Bird!
You're speaking of the top latch not the sides right? I pushed down on that to take off the passenger side but at the pivot points, where the latch connects to the part, the plastic got stressed and is about to break :(
