HOTLNC
LOD Officer
Well, the wife refuses to drive her car until I fix the "noise" in the front end.
I put the car on the lift last night and pulled the front wheels. There is a lot of play in the trans-axel before the opposite tire turns. And when you move the right wheel back and forth, working inside the play, you can hear metal rattling on the inner right side. Grabbing the axle, I can move it in and out about 1/16 of inch and that ain't right. The left side doesn't do that, nor make noise.
So, I'm figuring the right side inner constant velocity joint has lost its lubrication and started to wear. I'll pull the right side as soon as my tools get here (I ordered a front wheel drive tool kit from www.AutoPart.com. The kit sells for about 85 bucks and has a 17-1/2”long slide hammer extension, CV Joint puller, front hub installer, front hub puller and rear axle pulling plate.) You need all of this plus a 1 inch diameter, 24cm long wood dowel that you make yourself.
I bet you it's going to involve many, many magic words, before I’m done.
<sigh>
<sigh>
