Check THIS thread.... BTW, the search function is your friend:
From my manual:
Turn Signal and Hazard Lamps
The turn signal system consists of:
l multi-function switch (13K359).
l steering column/ignition/lighting control module.
l redundant directional flashers in the outside rear view mirrors.
l turn signal bulbs and circuitry.
The multi-function switch is an integrated switch design. When the multi-function switch is activated in either direction, or the hazard switch is engaged, a request is made from the multi-function switch to the steering column/ignition/lighting control module to flash the appropriate turn signal lamps, mirror indicators and turn signal indicators in the instrument cluster. The instrument cluster is equipped with a relay to provide an audible click anytime one or both of the indicators illuminates.
http://www.lincolnsofdistinction.org/vbulletin/showthread.php?t=28569&highlight=turn+signal+flasher
