Keatonsdad
Joshua 24:15
Does any one know where to get the hub centric rings and what size to get for stock hubs with aftermarket wheels. Are they specific to the wheel?
Yes they are specific to the wheel - the ID of the bore on the wheel to be exact.Are they specific to the wheel?
You can get the rings from the wheel manufacturer. Also, is you're steering wheel vibrating at higher speeds? Check the tires for "hop," or the run out on the tire. Ive seen many of tires be bad and cause issues. Or you can try a rotation, and see if it helps!
