i had an issue with that in a truck ..... once (cracked plastic intake) so i checked it when i had problems with my TC ..... turns out , what my issue was , there was a inch (or so) plastic pipe on the air cleaner plenum, coming out of the throttle body.... id almost call it a vacuum assisted transmission kickdown , except that is not what it is.... it just goes back into the block behind the firewall.... anyhow , the unseen end of this pipe had come loose and the car would barely run without it....unplugging the mat sensor from the air cleaner got it running well enough to get it to someone less old and fat than me....once that pipe was reseated , the car ran fine again.
