Installed T Bird AC discharge tube in Mark.
I put it in my 97 Mark VIII.
It works fine. It looks like it's made of aluminum, and it has 3 O rings instead of 2. The more, the merrier.:)
I used my original bracket and pressure switch.
I pulled the foam off the big muffler (or whatever) part to paint it.
Here's some photos:
Lownslowlsc
Is the T-bird one still availible new? Did you have to midify anything?
This is good to know as mines very rusty and will leak eventually.
M Darrah
A 94-96 T-bird discharge tube is what you want. RockAuto has it listed under "A/C Refrigerant Hose" for the 4.6. The 97, which I don't think is even available, has a slightly different configuration. Like Bill said, you have to swap the pressure switch because the plug is different. You also have to swap out the mounting bracket to fit in the Mark.
BTW, RockAuto says "3 available" but I don't know if that means 3 total or if they mean the "private label". In any case, you should probably get one while you can.
Yeah, thanks Mark, since you're the one that said this could be done anyway.:)
Yes, this one is still available, I got this one from Autozone, I told them it was for a 96 T bird with a 4.6L.
They call it an AC hose.:D
Lownslowlsc
Gotcha. Doesn't look like they'll be going anywhere so I prob just wait till it falls off. I've already spent way too much money this spring.
Theres only 3 left of the closeouts. :wink:
beerdog
I recently bought a NOS hose for the 98's and put it on my car. It had the upgraded design with 3 orings. i would have done this swap had I known.
beerdog
Here is an interesting pic. I cut the rusty one I removed open. It is just an empty can. I would guess it is not essential to have the muffler can but I have no idea.
95blklsc
Perfect timing, my 95 needs a new line, I think this is the one leaking, that can on it is rusted to hell. I'm sure it is there for a reason, but it does make you wonder how well it work work with just a regular line.
Thanks Mike, you saved me the trouble!
Looks like a muffler to me.:)
I knew my original was leaking, by the bright green oil on the bottom of the muffler part. It was oozing through the rust.:)
95blklsc
Here is another little bit of info regarding AC lines. Recently, with Jeremi's help, we put a mach 1 engine in my friend’s 93. Since the serpentine belt routing was different than the mark, it forced us to use the mach 1 ac compressor manifold to avoid interference with the belt. Unfortunately the mach 1 lines are smaller and in a different location. The AC system has been capped off until we were able to figure out how to mate the different sizes. We found a place, www.coldhose.com, that makes ac hoses to your specs. On the low pressure return side of the AC pump the mark line and spring fitting and barrier hose is a #12 size and the mach 1 side is a #10. The line was about $50 to have custom made. We ordered it just a little too long the first time around so a new one should be arriving any day now. If anyone wanted to try a high pressure hose without the muffler this would be the place to get it from. The high pressure line is probably a #8.
Also, the sizes referenced on their web site for all fittings and hoses are #6, #8, #10, #12, etc. They have a chart that correlates those to an SAE size. They COULD NOT tell me what the SAE size was referencing. I wanted to know if it was the ID or OD of the line, the fitting, the flare, WHAT was it? I talked to a few different people there and asked them to take a fitting off the shelf and measure it to figure out what I should be measuring on the car. This was too much of a complicated task for them and they told me they only deal with old cars and they couldn't help me. I told them the car it was going on was irreverent (and it WAS old), I just need to know what the dimensions reference! With a little bit of digging a found a document online that told me those measurements refereed the ID of the line before any flares or fittings.
Summary: Know what size fitting and hose you need from coldhose.com because the guys on the phone don't have a clue and won't find out. The product seems good though.
beerdog
did the MAch1 hose have a muffler? Plus, $50 is cheaper than new.
Was the line a hose only or a combinetaion metal tubing and hose?
95blklsc
The mach 1 hose is on the return side, the mark only has that muffler on the high pressure side. The original mark return hose only has a short section of rubber barrier hose, it was mostly bent steel tubing. To make things simple we just put a straight fitting on one side and a 90 degree fitting on the other with about 18 inches of #12 rubber barrier hose. I'll put up a pic when the new (shorter) hose arrives. We mis judged how long of a hose we needed and it was just going to be sloppy leaving the extra bulging out near the air intake tube.
Looks like Rock Auto put this hose as available for the 97 Mark VIII now. It's a little different, 45 bucks.
I guess they don't know it fits all years.:)
I was just looking for one the other day. With my little A/C trouble I had last week I better start gathering parts for when it fails. Thanks for the info Bill.
Gary123
My discharge line is also leaking
- - - Updated - - -
I'm new to this site and need 5 posts to add links
- - - Updated - - -
came up with this cross reference of part #s
Advance Auto Parts T55303
Atco 51540
Autocomp Technologies 40111298
Compressor Works 787040
Ford F3LY19D734A
Four Seasons 55303
Global Parts Distributors 4811291
NAPA 282887
NAPA TEM282887
Oreilly Auto Parts 55303
TRAD AUTOMOTIVE H5868
