I have a 2006 town car and I'm experiencing water on the passenger side front and rear floorboards. Has anyone experienced this and what was the fix. Thanks in advance. Jim
First check the cowl drain it is located on the passenger side it is a small flap on the lower left side of the cowl debris such as leaves will clog the drain causing water to back up .Remove the two plastic screws remove cowl and clean it out.
