Anybody know anything about them?
Okay I Had to replace the head gasket on my 97 Disco. Not to bad of a job for the most part. Bashed my fingers loosing the head bolts and got work out tightening the new head bolts. The very back bottom bolts sucked very tight spot to get at.
Now on to my problem. The thing will not start. It will crank, but not start. My dad checked for spark, by using a screwdriver and said it wasnt getting any spark. So I was talking with another car guy this morning and he said that you cannot check for spark by using a screwdriver. he said you have to pull the plug and leave it in the plug wire and then hold it against something like the exhaust manifold and that is the way to check for spark. He said that you could damage the coils by using a screwdriver to check for spark. Is that true???
Also when checking over things we pulled the connection plug that goes from the wireharness to the coil pack. With the key in the on position we show power coming from one of the wires out of 5 (we tested the wires coming out of the wire harness). Is this normal or should we see power coming from more of them?
Anybody have any clues as to what might have gone wrong with this? I know we are mainly Lincoln people on here, but thought maybe somebody might have some insight on what is going wrong.
