...and it's installed! About to go to work to do a voltage/charging check.
Everything looks good so far, As Driller mentioned, the alternator wiring was something of an annoyance, given that it's 20-year-old plastic wiring loom/insulation we're dealing with here, and I've had to cut it off (the short 4-inch piece of crappy plastic insulation between the three-pin harness plug and where it joins the main 12V charge wire) to gain some flexibility back into the wiring. Beyond that, some notes:
1. It's an even-tighter fit than the stock Mitsu turd. It clears everywhere...but just barely. If you're having trouble getting it installed, be patient, it will fit without having to grind everything.
2. I was hoping to retain the Lightning 8-rib pulley for some strange reason, but A. it's bigger in diameter than the MK8 unit, and B. It's too wide due to the coolant 'hoop' directly in front of the alternator being too close, meaning, you can't even get the belt off and on with it in place, it's that tight of a fit.
3. It took maybe an hour to swap it out, and that's even cutting off the old positive battery terminal, and crimping/soldering on a new one.
4. If you're patient with the wiring, it will work, you just kind of have to 'nudge' it over toward the passenger side of the car to get it to clear.
So far, so good, and although I found the original Apollo 13 control panel chaos oxygen tank explosion simulation rather entertaining (everything flashing on and off, practically every light either on or blinking, and shouting something or another about "Houston!" and "problems!"), it is also rather nice to have a non-eventful drive for a change.
I would have posted pictures...but really, there's nothing to this. If you've ever changed an alternator...well, there you go. You can't even tell it's got a different alternator in it, unless you're really looking for it.
Can an admin change the title of this thread to "Lightning Alternator"? Unless something explodes during the next test drive, I think it's in there.
