Nothing better than an AN oil return fitting standard !!!
Why did you go with the driver's side though ? Better clearance ?
[/div]
I did this because I *may* need to put air injection parts there. I do
not want a MIL. Joe doesn't know that because he doesn't know much about EEC-V cars. Rookie.
The guy who installed that is the same guy that modded my Bassani headers. Excellent work.
So the engine is Hensler Racing built .020 over, stock crank, 4130 forged steel ultralight rods from Coast High Performance, Diamond racing -5cc pistons, .5g balance, ARP rod bolts(2000) and ARP main/head studs, Federal Mogul race bearings, billet oil pump gears, Fox Lake ported and polished heads (stock valves), new bronze valve guides, new Cobra seals, Crower springs and Ti retainers, SHM Blower grind on the cams(regrinds). James also wanted to put in the Cobra tensioners with the ratcheting mechanism and I didn't want to pay, so he put them in no charge. He does not like the rods, and he does not like gaskets other than Cometic. He also recommended a billet trigger wheel, which I declined.
