Loss of power but only when
Rich00033
I am having a problem with losing power once to motor is warmed up when it's cold it runs fine but when it gets up to half on the temp gage it starts felling like the e brake is on but I'm not throwing no check engine lights it's a 94 mark I did eliminate the air box and run a cold air set up I made and ever since then it got worse I thought it was starving for air with the air box but now it worse anybody got any ideas ???
Maybe when it heats up something is expanding that allows air to bypass the MAF sensor.
tonybrooklyn
i would check fuel filter, fuel pump, Catalytic converter. Good Luck
Rich00033
What is normal operating temp for a mark with the air on in 95 degree heat any body know about where the needle should be? I think it running hot and when it starts running hot it starts acting up
Rich00033
Ok I think I figured it out guys I got the crc mass air cleaner and wow it changed the whole car any body having them problems try that first it would only act up when the mass air meter was hot
