Mark VIII intakes, front covers, valve covers for sale
Ponyfreak
I have up to 8 Gen 1 intakes for sale. Some are complete with IMRC's some are not. Some have the plenum removed and the runners shortened some are stock. I know for sure I have one intake that has been cut apart cleaned up with radiused runners and port matched IMRC's. This is the most expensive intake I have and want $100 for it. One that is cut apart with no plenum is $10. Let me know what you want.
I also have
2- 4.6 4V timing chain covers
1- Cobra valve covers - $75
1- Mark VIII valve covers - $65
1- set of Aluminum mark VIII LCA's and hubs - 75$
1- set of CP .030 pistons and H beam rods - $550
IF noone wants this stuff it is going on ebay like everything else.
Ponyfreak
1- set of CP .030 -18cc pistons and H beam rods with 50 miles on rings and pistons A couple rods need to be reconditioned since they spun a bearing. $550
1- BRAND NEW Torque plate honed .030 aluminum block ready to go with ARP studs. Block machined to work with the .030 CP pistons. $700
1- Steel crank was brand new and with only 50 miles on it. Was balanced with the manley rods and CP pistons I also have for sale. Rod journals need to go to .010 due to spun bearing. $225 I have about $850 in this crank.
Ponyfreak
I have a set of 96 IMRC's with the electric motors on them, but think they are gasket matched to an intake. I will double check and see what i have.
