Mark,
I do not have specific information on 1997 Mark VIIIs. If it is similar to a 1998 (which is very likely), there are only two fuses as well. They are fuse 4, which is hot with delayed accessory relay #1 or key in RUN position, and fuse 20, hot at all times. Fuse 4 also powers the compass, the factory radio, the passenger's seat module, the cell phone (if equipped), and the electronic day/night mirror (if equipped). Fuse 20 also powers the instrument cluster, (guages, tach, speedometer, and the shift position lights), also the automatic climate control module (ETAC module) So, check if the a/c heating system works. If all these systems work, it's not the fuses.
If you are still having problems and the fuses are good, check the grounds.
The list for the grounds depend on the systems it monitors. The grounds for the module itself are G103 and G301. G103 is on the lower LH front corner of the engine compartment. The engine coolant level sensor, the fuel pump/fuel gauge sender, and the message center switch assembly are also connected there. So, if the car runs and the temperature and fuel gauges work, that ground is probably good. G301, is located on the RH side of the floor pan, in front of the RH front door. You can check G301 out by turning on the RH rear reading lamp, or see if the right side window goes up and down. Also see if your air bag monitor works correctly.
The next ground is G104, located on the RH front corner of the engine compartment, on the front fender apron. That ground is for the washer fluid level switch. To quickly check it, blow the horns, or turn on your right hand directional switch with the key in the RUN position and go out a see if the right cornering lamp is lit.
G200 is next. That is located behind the center of the instrument panel, to the right of the radio. That ground is for the engine oil temperature sensor and the air suspension EVO steering module. That ground is an input for the "Check Air Ride System/System OK" indication in the message center. If you don't get an indication when you turn off your air ride switch in the trunk, this ground could be bad. Also, make sure your speed control and speedometer work because this ground is also for the vehicle speed sensor. Also, check out the right front seat power controls. Make sure the seat moves in all directions. Check all the switches and move the seat in all directions, because there are two grounds attached to that module and the book does not tell which ground does what.
G300 is located on the LH side of the floorpan in front of the LH front door. It is the ground for the compass, and lighting for the message center switch assembly. So, if the message switches in the middle of the dash board light, that ground is good. Also make sure the driver's window goes up and down.
Finally G400, located in the center of the trunk, on the end panel, (in back of the license plate in the trunk) is for the air suspension switch. So, if the suspension is OK, the ground is probably good. Also, check the license plate lamp when the lights are on. The rear lamps should also light. (left and right side marker lights, right and left rear parking lights, and if you want to try, turn the key to RUN without the engine running and put the gear shift lever in reverse and see if the backup lights work). The rear neon light is NOT an indication for this ground. It is grounded by G401.
If nothing is working on the message center, (no indication or messages), then check the fuses, and then G103 and G301. The rest of the grounds are for the respective inputs to the message center which are programmed into the message center when that respective wire goes to ground (except the air ride switch, which is backwards).
If you have to remove the module to check it out, the power connections are on both connectors. On C246, a black 12 pin connector, power from fuse 4 is on pin 10 (Black/Pink wire). On the other connector C208, a 16 pin connector, also black, from fuse 20, pin 27 (Red wire). Ground G103 is on C208 Pin 28 (Black/Light Blue wire) and the other ground is on the same connector, pin 36 (Black wire). If those connections are good and present, the module is probably bad, and you'll need to get another one. Make sure you check it out at the connectors before you buy another module.
The Gen 1 modules are NOT interchangeble with Gen 2 ones. You have a Gen 2. The Gen 2 has more connections, like "passenger's door open" instead of just "door ajar" and it also has the SCP or Standard Corporate Protocol connections that are used to transfer data from one module to the another. The Gen 1 message centers don't have this. If the colors don't match, you'll have to get someone else to help, because as I said, I do not have a 1997 manual. If the colors do match, and you check out the power connections at the connectors, check them with and without the fuses installed in the car. That way you're sure the colors are correct.
Hope the wire colors are the same and I hope this helps.
