BigBoyBoelts
So I'm rebuilding the suspension on my 94, or as I normally do I'm collecting parts to do it! I'm looking at doing a coil conversion, But what I want to know is do struts from a Thunderbird work on our cars? Reason I ask is cause I found a set of Koni adjustable struts for a 97 T-bird and I need to know if I get the conversion will these work with the springs or is there some special part that has to go on to work? If they work can I just use performance springs then too? What is the difference from the conversion that you can buy from Eddie to just getting spring and struts for a T-bird basically is what I'm asking. I already have the rear end all set so no worries there.
