Mystery hose....
Stergi0u
My check engine light came on today, the car is running smoothly, oil was recently changed as well as power steering fluid being filled. As I was checking fluid levels and looking under the hood for anything out of the ordinary, I noticed on the drivers side, high up sort mirrored to where the cabin filter is on the passenger side, there is a fairly thick hose that is only connected to anything on one side, I looked for any possible connection underneath and didn't find anything. Any suggestion to what this part may be? I will post pictures of the location and of the hose when it is daylight. Thank you for any help!
Its your Windshield Washer Hose...hit your squirters and see if you have water squirting from both sides of the windshield.
Stergi0u
It's in the center under the wiper blades and behind the air filter tube.
It's the one directly in the center.
For orientation you can see the two thin tubes making the V right behind the air filter tube.
That's it.
