R ryanharrington New member Oct 1, 2008 #1 picking up a repo parts car that someone went after the lock with a chisle and destroyed the passkey sensor. any ideas to get this thing running?
R ryanharrington New member Oct 1, 2008 #2 by the way we jumped the starter and it cranks fine but it isnt firing the injectors, but has spark.
driller El Presidente Oct 2, 2008 #3 On my '93 you can bypass the anti-theft at the relay in the passenger side kick panel. No fuel at all? Could be a fuel pump relay or possibly the cam sensor or harness.
J OCCUPY LoD :) Oct 3, 2008 #5 The SCIL module controls all the anti-theft switches and triggers. I was looking through the wiring diagrams and there is not one wire that you can bypass, nor can you just unplug the module. You might be SOL.....
R ryanharrington New member Oct 4, 2008 #6 ineeded toorder the sct runing software anyway which can turn off the pats. should be here wed
