New Member from NC!
984VMKVIII
My name is Jj. I am a 21 year old college student that also works at a junkyard full-time. I have had my 1998 Lincoln Mark VIII LSC for a couple of years now. The engine threw a few valve springs after being such a beast for some time and I finally put it out of commission. The engine and transmission are both removed, and the engine bay is clean. I'm trying to figure out what do I want to go back in there... If I wanted to, I could've just put the same exact setup back in, but while this engine is out, the 'while you're in there' mods are screaming my name. Long story short, I want a 5.4L to go in here... I don't care for the idea of just running 4.6 with forced induction. I don't care about building up a 4.6L in this car at all... If I had time, I would be sourcing an even larger engine to put in here, but there's a reason why I chose the 5.4L... I have a few things that all seem to fit together quite well. From top to bottom, here goes... I ported a stock throttle body with the IACV hole and knife-edged the throttle plates, I ported the 1999 cobra upper lid, I have the MMR spacer, and I cut open and ported the 99 cobra lower manifold. I do have some tumble port Intake adapter plates to make this intake fit onto the 5.4 block. The cylinder heads that I have going on the 5.4 block are the revised tumble port castings with the 9-thread spark plug hole; these are the DB casting cylinder heads. They have been ported on the exhaust side, 5-angle cuts on the intake side and I ported and polished the combustion chamber and measured each combustion chamber with the spark plug torqued to have a volume of 54 cc (there's a reason for this). They do have factory 96-98 cobra intake cams sitting in them, and I will be running a rear coolant pipe. I haven't done so yet, but I will be testing a Lincoln LS 3.9 V8 passenger side cam-chain tensioner on a scrap passenger side B head... if that doesn't work, I will be buying the MMR unit. The 5.4 block has been torque plate bored and honed to .020" over and I have some regular 2.66 cc dish 4.6 hyper-eutectic pistons that will be going in it. I also have a 4.6 Mustang GT oil pan (though I would rather a larger oil pan) and a MMR composite windage tray. Under drive pulleys, of course, and even tuning software (Delta Special Forces). I have new gaskets for literally everything, new hydraulic lifters and finger followers. New valve stem seals... Everything is new. There are a few more things that I would like to get, like an oil cooler, larger oil pan, and a custom connecting rod of 6.78" to complete this engine, but as of right now, I have the majority of the ingredients to build a very stout and powerful N/A 5.4L DOHC. For that reason, that's what I would like to put in there. My lincoln is the reason as to why I made this account, and I hope to hear some advise on this build from you guys. Thank you for your time.
Welcome JJ!
I think the 5.4 has been done, but not without significant hood clearance issues.. Nothing a sawzall can't fix though. :)
I thought there were some Hot Rod Power Tour photos of one a few years back, but I can't find 'em..
According to Sullivan, the 5.4L DOHC is approximately 2" wider than the 4.6L DOHC and the engine mounts would be the same.
The intake manifold may require some hood consideration. I would not recommend a 4.6L intake on a 5.4L engine.
The exhaust manifolds may cause problems.
The oil pan is going to require some modifications to the pan and/or the k-member.
Welcome! :)
