Go to HD or where ever you like and get a bottle of carpet spot stain remover, soak the carpet, scrub the carpet, then pressure wash (steam clean is better) the hell out of it. Then add a scented tree for effect. I removed years of toddler abuse from one just recently.How should I clean the carpet?
I can't wait to get the speaker installed today. I'm running all new wire and maybe new RCA wire for my amps.Good choice. I was just working with a very similar set in another Mark VIII recently. I was very pleased with the sound. Good, and clean. Not much on the low end, but I'm pretty sure they are designed under the assumption that you have subwoofers as well.
That a great ideal adding the cross over in the trunk. I order 100 feet 16 ga wire for the speaker. I think I have enough.The crossovers were mounted in the trunk. Jeremi gets all the credit for that decision, but I feel it was a good one. It isolates them from the less than weathertight environment inside the doors, and keeps them accessible in case you need to re-wire anything.
It does mean running twice the new wire, or as we did, consulting the Ford technical manual and utilizing the factory wiring. Since the two factory door speakers are wired separately to the trunk mounted amplifier, it is possible to utilize those wires for the new speakers. The tricky part is that the polarity does not seem to be marked on the diagram, so we had to make some educated guesses.
Running new wire to the doors is probably still the safe bet.
Can you tell us more about all the shinny stuff?
That is it. I get it from lowes or Home Depot$1 says it's "Reflectix" or similar.
Available from your local home improvement store near the ductwork wrap. a couple of my homebrew buddies use the stuff on their kettles to increase efficiency.
http://www.amazon.com/Reflectix-BP24050-24-Inch---50-Foot-Insulation/dp/B0009XCJA2/
I removed all the old smelly padding from my car and replaced it with the reflectix insulation. I hope it keep down the exhaust noise and engine heat.I just used THIS to sounds deadin my floor pan and just wondering if thats any better.
It's Photoshop.Dude, someone drew on your Westinghouse family photo lol
If you removed the needled cotton (looks a little like dryer lint) from the underside of the carpet, you removed a lot of sound absorber and de-coupler. I'm guessing the car will be louder in the cabin now.That is it. I get it from lowes or Home Depot
Found this info on www.reflectixinc.com/
Benefits:
• Radiant barrier
• Blocks 95% of radiant heat
• Easy to install
• Does not require any protective garments or respirators
• Convenient roll sizes
• Does not promote growth of mold or mildew
• Not affected by moisture or humidity
That why I installed the reflectix insulation.If you removed the needled cotton (looks a little like dryer lint) from the underside of the carpet, you removed a lot of sound absorber and de-coupler. I'm guessing the car will be louder in the cabin now.
