97CobraLSC
So I have a slow oil leak in my 97 Mark VIII.
It seems to collect on the drain plug, but I know that is not where it is leaking due to it being "wet" above it.
I know the Oil Filter Adapter Gasket typically goes bad, but supposedly it was replaced recently.
Is there something else that commonly goes bad and leaks?
Kicker: It leaks faster when parked and the front end is lower than the rear. I had it jacked up in the rear and front normal height and it leaks significantly faster.
My brain says that the O F A G is bad, but I'm not sure.
Is the best way to tell is degrease everything and watch it? Help is appreciated.
