.... No. I went off of what the computer told me. I'll check at lunch.Did you check the oil level on level ground?
If you wait for the computer to tell you that you are low on oil, it's too late..... No. I went off of what the computer told me. I'll check at lunch.
that should be the first thing you check, 1 qt low can set off the light..... No. I went off of what the computer told me. I'll check at lunch.
Thanks. I'll throw a bit of oil in there and see. I doubt the engine's been abused. I purchased the car from a 30 something year old college educated guy who owns an early 2000's cobra. The car was his grandma's (original owner, the car was even still in her name), and she passed away 13 months ago. He and his mom have put maybe 2,000 miles on it in the past year, and oil was put in at firestone/pepboys/midas in march. There was a layer of dust on it when I went to see it at the grandma's condo, which I'm guessing they're about to sell. There's a binderful of receipts, etc, so it looks like it was well maintained. It doesn't leak at all. Maybe "namebrand store" only put in 5 quarts?^ That's a great representation of the dipstick imo. Nicely done! I wouldn't think that would cause the light to come on but try adding 1/4 to 1/2 of a quart, I'd be shocked if it takes more than that.
While we are on the subject... When I bought my car it had "6.5 qts" written on the LH shock tower cover. My buddy has an '03 Cobra and says the Cobra guys run 6.5 to 7 quarts all the time. Someone even showed where 6 quarts sat in the pan compared to 6.5/7. I've always ran 6.5 in mine.
Yeah it's nice and quiet. Like I said, even when revving up to the redline it's smooth and no noises. I read a couple of other places (http://www.markviii.org/htdocs/dc/d...orum=21&topic_id=47800&mesg_id=47800&page=345) that it could be the sender or a bad connection (hence my assumption, because there's no mechanical symptoms). But, I've never blown an engine, so I don't know what I should keep an ear forSounds like a nice solid car! It calls for 6 so no place should be putting 5 in it but anything is possible. I'm pretty sure from how you described the oil level it isn't a quart low.
No fears about frothing oil? I guess 1/2 a quart isn't that much. Would being a little low like I am make the sensor go off?Like others, I run 6.5 quarts of oil capacity. The heads circulate a tremendous amount of oil and are slow to drain back to the sump, especially at high rpms.
I wouldn't think so? Mine has been as low as the "add" line and I have never seen a light of any kind. I've never allowed it to go lower.Would being a little low like I am make the sensor go off?
As far as the Cobra guys say the pan holds much more than Ford specs it for. I wish I had the link for you from the Mustang boards that went into the detail and showed what 7 quarts looked like in the pan and it's relation to the crank etc.No fears about frothing oil? I guess 1/2 a quart isn't that much. Would being a little low like I am make the sensor go off?
The low oil light isn't illuminating. Just the pressure light at high RPM. The alternator looks newish, but not super new. Maybe replaced 2-3 years ago?I wouldn't think so? Mine has been as low as the "add" line and I have never seen a light of any kind. I've never allowed it to go lower.
The "Low oil" light on my '86 Lincoln wouldn't illuminate unless I was well below the "add" line.
Another thought.. when the regulator started going out on my alternator, it caused all sorts of electrical glitches.. I don't know how you'd test for this.. I'd just keep it in the back of your mind.
I'll take a look inside the head / in the cap. I think it has been regularly changed... I'll go through the paperwork and take a look. Is the oil filter visible from viewing top down, or do I have to crawl under to take a look?I wouldn't put another half a quart in there if it's that high on the stick. Overfilling it isn't going to help anything. The oil doesn't have to be filled to the brim to have enough oil pressure. I would change the sender like you said.
This is a shot in the dark but some quick lube places put a mini oil filter on to make things easier on themselves. They are also extremely cheap crap filters. I don't know if that would have an effect?
Can you tell if the engine has had regular oil changes? Does the back of the oil cap look sludged? Does the head inside look oil caked?
I thought the cobra has a different oil pan then a Mark?As far as the Cobra guys say the pan holds much more than Ford specs it for. I wish I had the link for you from the Mustang boards that went into the detail and showed what 7 quarts looked like in the pan and it's relation to the crank etc.
Driller knows his stuff so if he says 6.5 I'm happy that's what I run too
