You remove the shifter handle.next question........
i removed the shifter bezel and can now see the actual shifter mounts. do i need to actually unbolt the whole shifter assembly or maybe just the shifter handle itself??
if it's just the handle i don't see how it is attached. i'm sure i could figure it out but i would rather know in advance so as not to break anything!
(note) i can see a few little solder balls floating around down near the mount, so i'm assuming someone has done this before!
Shift Knob
Removal
1. Remove O/D lockout switch using a small screwdriver and gently prying between switch housing and knob assembly.
2. Remove retaining clip from shift knob.
3. Hold shift knob securely and depress release button.
4. Pull up on shift knob.
Its at the front of the handle (facing the A/C controls), feel around and you'll notice an indention that is partially hidden under the leather. Stick a small flat head in there and pry out. The clip is shaped like a staple and will come out easily. Its easy to see if you turn the key on and shift the car into 1st gear (with the parking brake on).
