Plz Help Rear Suspension
cowels88
Hi everyone im new to the forum and site. I have a 00 lincoln ls with 100k on it. Im getting my front and rear suspension done at least most of it. And I found all the parts except a tie rod assembly for the rear. Tha shop I went to said that's what I needed and want to charge 300 for it. So I looked on line and can't find any tie rods or tie rod assemblies for my car. Starting to think theydnt exist for the rear. Someone plz help.
beerdog
Welcome to the club. You might want to also post on lincolnvscadillac.com. There are more LS owners on that site. Many of our members are also members of LVC.
calisonic
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.2.1; en-us; SAMSUNG-SGH-I897 Build/FROYO) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
Unless the ls has four wheel steering, there is only tie rods on the front as far as I know.
Check RockAuto.com. We have a discount code for the site and can get a deal. Also, copy the part number and paste it in Amazon. You'll find parts cheaper through Amazon because you don't pay tax or shipping. :)
calisonic
Are you sure its not "inner" tie rod?
What are the symptoms?
cowels88
When the shop inspected my suspension they said the bushings in my lower control arm were out that's y my car was making a loud squeaking noise when I go over bumps or when someone sits n the back seat it would make. That noise. They also said I needed 2 sway liinks and 2 tie rod assemblies In the rear. Still tryna figure out what is tiie rod assembly can't find them.
calisonic
Some cars do have them it seems. Bot the same as your traditional tie rod though. See if this helps
http://www.lincolnvscadillac.com/showthread.php?t=44210
Then call your local ford Lincoln dealer and ask for it and or tue part number. They do exist.
cowels88
Ok his so I got all my suspension parts today. My car has.been sitting for a month and so half now so end battery was dead. I got a jump and it won't start. I tried spraying starter fluid into the intake and still no start. I went to put gas in it an it won't start. Before I decided to stop driving it a month ago till I got the rods done the car would start with no problem. Please give me some ideas
Wirelessly posted (Mozilla/5.0 (iPhone; U; CPU iPhone OS 4_0_1 like Mac OS X; en-us) AppleWebKit/532.9 (KHTML, like Gecko) Version/4.0.5 Mobile/8A306 Safari/6531.22.7)
Unplug an replug in the crank position sensor too. It's right below the A/C pulley.
