chadly
Got everything done. Car starts but wont hold an idle. If you hold it over 2500-3k rpm's it is fine but under that it bogs down (stumbles hard) and dies. Had the wife do start while I looked under the hood but couldnt find anything obvious. I thought maybe the IAC vac line was getting cut off but it seemed fine. Everything is plugged in where it should be, TPS is wired correctly. What else do I need to check?
