Puddle Lamp Function
markup97
Lost in Translation
After some searching, I have come up with 'The Puddle Lamps come on when you unlock the doors or use the remote/keypad'. While this sounds pretty straight-forward, I do have a question related to their function.
Mine do not work on my 97 Base, and both bulbs are good, along with the fuse. Any ideas as to why they aren't coming on (I unlock my doors with the key versus remote/keypad). Do they not come on when physically using a key or do I have a problem elsewhere in the system?
markup97
Lost in Translation
So, it looks like I need to find a key fob and have it programmed to my vehicle then!
Thank you to those who replied, and now I have the direction to take the problem in!
enriquei
You can program it yourself. IIRC, from what I've read, it's pretty simple.
markup97
Lost in Translation
Due to the nature of my car, it presents a unique challenge. The code for keyless entry I have (on the sticker next to the air ride control switch in the trunk) is not correct for the computer in the car. My car is a half-breed, as in it is a 1997 Base with a 1994 rear clip. See my 'Members Rides' for the entire reasoning. it would probably be better for me to get a key fob and take the car in to the dealer and reprogram both at the same time.
The code should also be on the driver door module, you will have to take the door panel off. The code is directly relate to the controller not the computer.
markup97
Lost in Translation
Steve,
So you are saying that no matter the year of the car, the code is held in the controller versus the cars EEC-V?
chris2523
on first gens it is absolutely not in the EEC. i assume it is the same for second gens, as they have that controller in the door.
markup97
Lost in Translation
Excellent. Thank you for that information.
When I get the car up to the dealer for the Cruise recall, I will have them program the fob!
If the previous owner thought to leave the manual and associated materials in the glovebox, I believe the keypad code should be included on a little "business card" in there, as well.. It may save you taking the door apart.
Alternatively, do some searching on-line for a "brute force 5 digit PIN" cracker, and grab a couple 12 packs and a lawn chair. :D
markup97
Lost in Translation
Key Fobs still available from Ford ($60) but no warranty that they can be properly programmed. Found a control in the yard today and yanked it (just to have a spare module). Once I get the car back together and up to the dealer for the cruise Recall, I will try my luck and see what comes of it.
