pulls left when braking
pinball
Hi I'm new member and this site looked very informative.I puechased a 1993 mark vlll recently as I always yearned for one. It has a hard pull to left when braking prev owner replaced pads and rotor and calipers front end looks tight owner replaced joints etc.Mechanic want to replace brake system,believe it is hydraulic problem.any suggestions?:wave::wave:
Welcome!
It could also be a sticking caliper, easy to check, jack the front of the car up and spin the wheels.
My first car (1977 Pontiac Ventura) had a issue where it would pull hard to the right when breaking. New calipers etc, did not help. Turns out there was a crack in one of the rear leaf springs, replacing them fixed the issue. So also inspect suspension components.
pinball
Hi adding another sympton to the pulling to left is that after making a turn the steering wheel does not track to center .Fluid levels in power steering is full
Thanks any reply
