Rear Air Bags Won't Inflate
snub
It's a '94. Car has been sitting for about a year. It is totally slammed in the rear, but the front bags inflate just fine. Message center is not showing anything. I replaced the rear shock bushings a few years ago and replaced the front upper control arms about a year ago. I don't know if either would be related to my problem.
BadSax
enjoys 3 martini lunches
Is it possible the rear ride height sensor has popped off one of the studs, so the car doesn't realize the back end is not at the correct height?
Otherwise I can't think of any reason why you wouldn't get an air ride warning... :love-it:
snub
I jacked the back of the car up a few times, nothing changed, so I got the car running so I could better position it for removing the rear wheels. I put my foot on the brake so I could move it out of park....then the compressor cut in and filled the rear bags. Don't know what it was but hopefully it keeps working.
Thanks for the help!
BadSax
You're very welcome... :D
Like I said, just put the car in gear... it'll lift right up and be fine. :D :D :D
