Please, correct me if I am wrong, but I heard these(stock 94 Mark VIII) Trans have a feature that basically works like a true "manual valve body".. in other words, if you start off in 1st, it stays in first, until you shift to 2nd, in which case it will stay in second until you shift to Drive(3rd). If this is the case, can you just start out in Drive, and at about 5750 rpms(or any desired rpm) manually pull it down into second? In other words, does it matter if you start out in first, or drive, as long as you shift it when you want to, as opposed to letting it shift itself?
The reason I ask is, when left in Drive, at W.O.T., my STOCK 94 tends to "nose over" at 6000 prior to shifting itself to 2nd. If I manually pull it into second at about 5700 or so, it doesnt nose over, it just squats, chirps and goes.
I'll be running my car down the 1320 tomorrow(Wed) and I want to run the best e.t. possible. the catch is, we only get about 2 time runs before elims start, and I havent raced this car yet, so I dont want to be all over the place e.t. wise since I will have to dial-in after only 2 time runs. Not exactly the best time to try out a few different methods, so I thought I would ask those that have already tried them all.
BlackIceLSC-VP LODNCA
http://mark8.org/lodnca
94 Black/Black M8
95 Champagne/Saddle M8
