John, the install is fairly simple, you don't even have to raise the car. All you need is a "pulley puller set", you can borrow Pepboys or Autozone, an impact wrench and some high temp silicone.
Here is what I did:
1. Disconnect the battery
2. Disconnect the electric fan
3. Unbolt the two bolts that hold the fan in place
4. Move/slide the fan closer to the engine so that there is a gap between the fan and radiator about 1-1.5 inch. you might have to bend the bracket that holds the battery cables if it gets in the way.
5. This was the hardest part for me, "zig zag" the fan from left to right while still maintaining that 1-1.5 inch gap.
6. Now you have a clear work area, use the impact wrench to remove the bolt
7. Use the "pulley puller set" to remove the pulley
8. Put some high temp RTV silicone on the ridge of the new pulley
9. Use the impact wrench and the bolt they have supplied to set the pulley in place
10. Take out the pulley you just put in and put the original one back in
11. Start putting every thing back and your done
______________________Mark of the Cobra______________________
http://dtw.truckmoxie.com/forums/images/badass.gif
David J
