I would like to add my thumbs down for the Moog strut rod bushings particularly the ones at the frame. I am on my 3rd Mark VIII.
I have all Moog front end parts. Control arms and tie rod ends last 100,000 miles just like the oem parts. Sway bar end links somewhat less.
Strut rod bushings simply do not. 30,000 tops. I now use only Ford bushings.
When you hit the brakes 1000's of pounds of force pull on the strut rods. Moog's bushings compress but are not elastic enough to completely expand back into shape.
Over time they develop play and your car starts pulling to one side during braking.
Neil
I have had no luck with Moog upper or lower control arms Junk IMHO.
I am very happy if i get 30,000 miles out of the strut rod bushings.
The increased firmness and tighter cornering are worth it to me.
That's 6 years of driving for me.
At $30 a pop and an hour of my labor i am golden.
You see i refuse to get raked over the coals.
And pay hundreds of dollars to do both sides.
Last i checked about 75 dollars a side.
That's with out the sleeves.
Those bushings where about 6 bucks a piece.
Before they realized there where people willing to pay much much more.:fart
- - - Updated - - -
For a couple dollars more I would have gone OEM. Alignments get expensive if the front end keeps failing.
As long as you don't remove the lower control arms.
No alignment is needed.
Only a few measurements need to be taken.
