... and valve covers. You'll also need to swap the power steering reservoir bracket and remove the passenger side coil bracket.everything except the heads and block.
the intake/IMRC's and IMRC motor, fuel system, electrical system, cruise control system, ignition system, PCM, relays and sensors....all different pretty much.
Ahhh... yes.I am also pretty sure there are emission components that went with the 98 (OBD-II)that you'll have to modify to work on the 93 (OBD-1)
