Sway bar bushings.
calisonic
Any one know what size to get for the front and rear and where to get some decent poly ones? I know SCP has them but every other site lists like three different sizes. I fmy measurements are correct its 1 1/16" or 27mm on the front and 7/8" or 22mm on the rear
calisonic
Wirelessly posted (SAMSUNG-SGH-A877/A877UCID3 SHP/VPP/R5 NetFront/3.5 SMM-MMS/1.2.0 profile/MIDP-2.1 configuration/CLDC-1.1)
well i found some at napa that should work for the rear and i got the scp ones for the front. Ill post the results once ive done them.
calisonic
Installed the front ones last night, definitely help with body roll. I will be doing the rears either today or next weekend at a friends shop.
tixer
Lincoln Evangelist
I'm not really sure. It's possibly Jay is, as he picked up some of Doug's supplies and plans..
Alternatively, these would not be too difficult to fabricate yourself with some bar stock and a cut-off bit for a rotary tool.. (And patience.) You could use the Energy Suspension bracket as a template for the backer plate.. but do note that you have to trim a corner on each of the rear plates, as well as the bushing bracket, as shown in the photos..
I do have Doug's kit on my car, and it's fantastic. This is a mod that's worth doing. (Particularly if you've already broken one of the stock brackets, as I did.)
98mark8lsc
I make stuff
These would be quite easy to make with a cad file on a plasma table. ;)
I think that would add considerable cost too. A strip of flat bar stock cut with a sawz-all, or cut-off wheel should be cheaper. I could probably get my water-jetter to make them pretty easily, but I'm sure it's much cheaper to just use the bar stock.
As of right now, I've got too many other things going, and not enough disposable money, to work on these right now.
I plan on it in the future, just not now...
chestnut101
theres a young soldier at Ft stewart that needs a set . i just used mine on red rescue. and he showed up with a broke rear swaybar.
