The Mark 11.751 @ 120.80
maxmk8
Congrats mike!
Any plans on making this car any faster? Anything faster would affect streetability no?
mlschultz
Boost King
Thanks, Max. The Mark is very tame on the street. Aric did a fantastic job tuning it for the street. :) I do not plan on a roll bar, so racing it at Atlanta Dragway will be kind of tough going quicker than 11.5. So, that is where I will stop.
I will say, this car will do much better than 11.5. :)
maxmk8
Don't forget to update your sig :D Awesome accomplishment !!!!
Burbank 98 LSC
Congrats on new times and welcome in the 11 sec club.
Just don't bother with rollbar and come to my local track(US41) and get some low 11's or possible 10's.
Some people think when you have 11 sec car the streetability is bad but I think those cars are different as I always drive to race track(60 miles each way) then drive back home with no problems and averageing 20 mpg.
46callaway
Mike told me on the other forum that the 11.7 was with a 1.9 60 foot time so the car still has a bunch more in it!
mlschultz
Boost King
Thanks, Guys. Atlanta Dragway is 80 miles from my house, and I drove it to the track and back home.
There is another track - Silver Dollar Raceway, in Reynolds, GA, that is about 150 miles from my house. They seem to be a little more relaxed with the rule book. Once I figure out what I am going to do with the slicks and rims, that is probably the track I will go to for some more tuning. :)
Congrats Mike. I'm sure the Mark will see faster times yet. ;)
Those Maurauders sure were tough this year. :D I know the one you ran against quite well.
mlschultz
Boost King
Thanks, Guys :) Yep JP, Sherman is a legend in the Marauder world. Did you happen to see this picture? Nuff said about Sherman... :)
Sierra3
Sweet, thanks for sharing the video Mike. Man that car is 100 percent different. I like his shift tune schedule hes done also. You can hear it making use of all of the available RPM. Sweet. Wait for us to catch up to ya now. Watchout Burbank. The Darth Vader is coming for you. lol
Yep JP, i can see it going much faster in the future. Can't lay all the cards on the table first time out right?
Very nice.
mlschultz
Boost King
Sure, There are a couple of them out there. :) Here are some threads from different sites.
http://www.markviii.org/htdocs/dc/dc...ng_type=search
http://www.markviii.org/htdocs/dc/dc...d=67260&page=4
http://www.markviii.org/htdocs/dc/dc..._id=5855&page=
http://www.markviii.org/htdocs/dc/dc..._id=9588&page=
http://lincolnsclub.org/vbulletin/sh...6&referrerid=5
http://lincolnsclub.org/vbulletin/sh...0&referrerid=5
http://lincolnsclub.org/vbulletin/sh...9&referrerid=5
http://forums.tccoa.com/showthread.php?t=101521
http://forums.tccoa.com/showthread.php?t=107337
Here is a list of most of the mods/parts done to The Mark in the past few years:
M2300X Ford Racing/Brembo 13in 2000 Cobra R Front Brake Kit 136-2261002 Baer Eradispeed Extreme Plus 2 piece Front Brake Rotors for 1999-2004 Mustang Cobra DP31031C
EBC Brake Pads for 2000 Cobra R/Brembo Brakes
9904HABA Front Hub and Bearing Assembly for 1999-2004 Mustang Cobra 136-2262001 Baer Eradispeed Extreme Plus 2 piece Rear brake rotors for 1999-2004 Mustang Cobra
YR3Z1109AA Rear Hub for 1999-2004 Mustang Cobra IRS
E9DZ1215A Rear Wheel Bearing for 1999-2004 Mustang Cobra IRS
BR57B Rear brake pads for 1994-1998 Lincoln Mark VIII
Big Ed's Caliper Relocation Kit
Classic Tube SS Brake Line Kit
F&R Custom Forged Boze Wheels Front wheel dimensions: 18x8 w/ 6.375 back spacing
Custom Forged Boze Wheels Rear wheel dimensions: 18x9 w/ 7.500 back spacing F&R
Wheel Spacers - 1/2"
Front - Toyo Proxes T1R 255/40ZR18
Rear - Toyo Proxes T1R 285/35ZR18
Vortech Supercharger HD bearing T-Trim Polished
Treadstone Intercooler TR10 24in Long core
Custom Polished Aluminum Intercooler Tubing - 3 1/2" intake, 3" discharge Siemens Deka 60lbs injectors
Ford GT supercar fuel pump
ATI 10% overdrive 8 rib balancer damper
Kenne Bell Boost-a-pump
NGK BR7EF Spark Plugs
Ford Racing Aluminum Radiator 03/04 Cobra. Fits 97-03 Mustang/Cobra Electric Fan 2002 Mustang GT
PMAS MAF for 2005 Mustang GT
MAF Plug for 2005 Mustang GT VMP MAF adapter for 2005 mass air flow sensor into aluminum tubing
MafXtender
Kooks 3/4 Headers
Magnaflow polished SS mufflers
Magnaflow high flow cats
SCT Xcal2 Flash tool
2 1/2" Custom mandrel bend SS exhaust
PI multi disc 3600 stall torque converter
Dynotech Metal Matrix Drive shaft
Ford Racing 410 gears
Ford Racing Trak-Lok Diff
Raxle SC T-Bird rear half shafts
SCP Pinion Brace Poly Diff Bushings
SCP Rear Cover Brace
Bradshaw Bros. Custom built 500 rwhp racing 4r70w transmission
Ford Racing deep well trans fluid pan
Custom built Ford plate style trans cooler w/SS braided lines
Pioneer in-dash navigation system and multi-media head unit
Myron-Davis DVD player
Polished 96-98 Cobra Intake
2 - Vortech mini race blow off valves
Polished ACCUFAB Single blade throttle body
Reichard Racing Ultra Grip Pulley
Injected/Proline Racing Engines 302 Stroker Kit
Custom Manley Pistons-off set
Manley H-Beam Rods
ARP 2000 Bolts
Total Seal Stainless File Rings
Federal Mogul H Rod & Main Bearings
ARP Main Stud Kit
ARP High Tensile Strength Head Studs (with 12 pt nuts)
Melling High Volume Oil Pump with Billet Gears
Refresh Cylinder Heads
MET-MBR0004 - Screw in type valve cover breather
FOMOCO-XR3Z6B209DB - Steel tensioner recall kit for 96-98 Mustang Cobra INJ-9603MT - Injected Engineering manual serp belt stabilizer OEM-MC-PW470 - Water pump for 96-98 Cobra
OMOCO-F3LY6K297A - Timing chain guides
FOMOCO-1R3Z6M256AA - Timing chain guides
FOMOCO-1R3Z6L253AA - Timing chain guides
FOMOCO-1R3Z6L253BA - Timing chain guides
FOMOCO-F7LZ6K254AA - Timing chain tensioner for 4.6 4v B Head FOMOCO-F7LZ6K254BA - Timing chain tensioner for 4.6 4v B Head FOMOCO-YR3Z14300BA - Mustang Cobra/GT Pos and Neg Battery cables
KempoDavid
MafXtender
Kooks 3/4 Headers
Manley H-Beam Rods
ARP 2000 Bolts
ARP Main Stud Kit
so, just a couple of bolt-ons, then? :p
this is my favorite
"Pioneer in-dash navigation system "
I bet you have to slow down so it can keep up!
Be2lose
In title only.
WOW I've got to show this list to my wife!! She thinks I spend to much money on this car!
It would go something like this- Me "But, Honey look what I could do." She looks and just walks away mumbling something. I don't know but it probably would sound something like "When pigs fly." LOL
