So...tie rod ends have a torn boot, but are still solid. It appears that the clunking is coming from the strut rod frame bushings; they're finally shot. The car is pulling to the right, which I kind of suspected was possibly due to reassembling the front end last spring to as close-as-I-could-eyeball. Also there's a pulsating while driving, which I thought may still be the brake rotors, even though the vibration fed back to the steering wheel. I'm guessing the severity of these symptoms are just exacerbated by the worn bushings. Now to decide rubber OEMs or Poly? And at the same time, I'm guessing I may as well tackle the tie rod ends before they DO wear out, and while the strut rods are out, maybe try and tackle pulling the K member and work on that stinking oil pan/gasket...
