k leo. i just did i test... I just waxed a portion of my test bench, sprayed it with water, Saw the beading action and saw the protection of the wax.
Then i used pinnacle Clay lube, and Meguiars white clay, and clay bar'ed the surface. I wiped down the surface. Then i repeated the spraying of the water on the surface. No water beading or rolling ocured, The wax protection Was gone... as it is everytime you clay bar your car. you are removeing paint contamination on the paint surface... Wax is on the paint surface... to remove surface fallout or contamination on the paint surface... everything else must go.... if you want pictures of the following test.. or a even more meticlus test, or you want a diffrent wax used Let me know.
