Ok, no cigar. The old one leaks like a colander (do sleeves leak?).
Anyway, when started and the old tube in place, along with a new EGR valve and ESR, the motor runs like crap. If I remove the EGR's vacuum line, the motor smooths out. So the tube is leaking enough to give false pressure reading to the computer, via the EGR.
Here is a picture of the two tubes:
I've removed the insulators from the tubes. The VGR side is on the left. The right end connects to the catalytic converter. When mounted on the cat, the new one sits below the output port of the VGR.
I've got a search going for the tube, using a paid service. The top tube is the ONLY tube that crosses by part number with Ford/Lincoln.
