sorry i kinda forgot about this post.
most likely thing to go wrong is a wheel speed sensor. pull the wheels off one by one and make sure they're all still there, all still aligned with the sensor rings, and all the wires are still good and connected properly. If that doesn't do it, pull out the light bulb that is telling you it ain't working and forget about it. ABS isn't really worth the money to fix if it's anything more complicated than a wheel speed sensor or a fuse. Just make sure you know how to handle a vehicle in slippery situations with no driver aids.
BTW the T/C on the gen 1's works solely by applying the rear brakes if it senses wheelspin below 34 mph. After that it shuts off. It uses the ABS system to apply the brakes, so if there's an ABS fault, the t/c won't work.
