Vortech belt question
mlschultz
Boost King
Here is a picture of my original belt number that was used with the pulley that came with the Vortech. Not sure it mattered, but I had the stock tensioner. NAPA belt
crash
So that's a 112" you used with the stock 3.6" vortech pulley? After much searching, I know people have used the 113" with the 3.6" pulley. So I was just wondering with the smaller 3.33" pulley, does it make much of a difference that I would need a shorter belt? Plus that 112.5" belt listed above is $14 cheaper than the 113".
mlschultz
Boost King
Yep, that belt was on my original blower that had a bearing failure. The replacement blower has a 3.1 pulley on it. I do not have a picture of the belt used on that one. My new set-up has the 10% overdrive damper with the 3.1 pulley, so that belt size will not help any. I will get a picture of it anyway, just to see the difference.
A pull on the dyno will tell you if you have any belt slip. That is one way to know for sure the belt is too big.
Lonnie
Blue Oval Chips
Stay with the 112 - 112.5. The Cobra for some reason doesn't have the range that the stock Mark tensioner has. I used to have a connection on reclocking plates for these tensioners but have since lost that info.
