Where to get rear caliper tool?
Topcat
Mac Tool and SnapOn have excelent tools but you are going to pay....I have the SnapOn never lets me down
maxmk8
That dreaded cube tool wasn't that bad... 20 min and the caliper was in, if you got someone helping ya. Let me know if you need some help.:7
maxmk8
You can get the $10 tool at your local Schucks/AutoZone to work, but you may have to grind down a couple of "nubs". Here's a pic of what I used:http://www.mark8.org/lod/braketool.jpgI bought the tool above at NAPA.Kale
[/div]
Ditto on the grinding but it works with a little force x( .
Kale
How could you break the tips that you ground down??? LOL! I'm assuming that is a typo since you wouldn't be using the tips that were altered, and even if they did break off it wouldn't matter. The tool worked great for me. If you really get in a bind, it wouldn't be too hard to fab something like this up...
Kale
HOTLNC
LOD Officer
NAPA has a tool that I use. The cube sucks as it is just a little too small after grinding off the two extra ears.
Search for NAPA in this area and the part number can be found.
NAPA part number 3355 (it was bugging me.)
magic_marker
This caliper tool came today and looks very well built! It also looks like it will make changing the rear pads very easy! I'll let you know how it goes...John[link:mark8.org/lodnca|NorCal Chapter Website]http://mark8.org/users/johnaec/Mark_VIII_s.jpg'97 Mark VIII LSC'96 T-Bird 4.6L
[/div]
Please do let us know!
One thing I noticed (when doing the rear brakes on my wife's Jetta) was that the "plate" part of the tool is fairly thick. Her rear pads were down to the metal, so the piston was 'out' pretty far. As a result, I couldn't get the tool in between the piston and the caliper bracket until I was able to manually retract the piston a little bit. That was frustrating.
johnaec
It works great!
I got that caliper tool from Tool Paradise and did the driver side rear last night. ('Ran out of time - 'doing the passenger side tonite.)
This tool is awesome!! The #7 plate fit the Mark VIII perfectly, and I didn't have the plate thickness problem mentioned even though my pads were grinding metal! And having a threaded slack adjuster to keep it snug against the piston made turning the piston in the easiest part of the whole job.
BTW - when you get the piston in, be sure to leave it with the adjusting slots pointing straight in and out so the pin on the brake pad will slide in.
Here's where I got the tool:
http://search.cartserver.com/search...ry=databaseDescript&maxhits=5&keywords=AP7860
John
'97 Mark VIII LSC
'96 T-Bird 4.6L
maxmk8
RE: It works great!
BTW - when you get the piston in, be sure to leave it with the adjusting slots pointing straight in and out so the pin on the brake pad will slide in.Here's where I got the tool:http://search.cartserver.com/search...atabaseDescript&maxhits=5&keywords=AP7860John[link:mark8.org/lodnca|NorCal Chapter Website]http://mark8.org/users/johnaec/Mark_VIII_s.jpg'97 Mark VIII LSC'96 T-Bird 4.6L
[/div]
Tell me about it! ::roll:: That took me like 5 min of agony to figure out ::nono::
