BlackMark8
Ok so i bought a 93 mark and put a new waterpump in it... started to drive it to my house, which the motor makes a horrible tapping sound at around 1500 rpm to about 2500 rpm, sounds terrible but clears up when you past that rpm range.
So i bought the car with a bad water pump, i changed it. Started to drive it home and i noticed the car wouldnt come out of 2nd gear. if i left it in 2nd it would stay but when it tried to go in 3rd it just starts slipping like its in nuetral and wont go. But before i could even check the fluid level, i look down AND THE CAR IS OVERHEATING !!!! wtf i just put a new waterpump in ! . And i failed to find the thermostat? where is it on the 93? is it an in-line thermostat, i took off that rail with the hoses on it but i dont see a thermostat.
