Proper use of a torque wrench helps too!!! None of that "elbow click" torque works!Any time I'm threading a steel fastener into aluminum, I always make sure to use anti-seize. Future dis-assembly will easier, and much less likelyhood of broken bolts/studs etc.
Learned that years ago on a motorcycle.Any time I'm threading a steel fastener into aluminum, I always make sure to use anti-seize. Future dis-assembly will easier, and much less likelyhood of broken bolts/studs etc.
So do you take anti seize when you are constipated then :fartReady for this little fact, you don't need to spend money on special anti seize compounds... use Maalox! Yes that's right, Maalox works just as well. Been using it for years with excellent results. Makes you wonder what's in that stuff!
http://www.maaloxus.com/index.shtmlWirelessly posted (Mozilla/5.0 (iPhone; U; CPU iPhone OS 4_3 like Mac OS X; en-us) AppleWebKit/533.17.9 (KHTML, like Gecko) Version/5.0.2 Mobile/8F190 Safari/6533.18.5)
Lol! What IS Malox?
yep me too. everything i take apart on my car.Everything INCLUDING lug nuts. For those who thing anti-seize is going to make a torque fitting lug nut come off....youz crazy. Lol! After replacing wheel studs from rusted lug nuts, they always get the silver goop.
When doing brakes, I put it on the back of the pads, the bracket surfaces, the caliper slide pins, the caliper bolts, the hubs (like steve said)(I've had to sledge rotors off before...not fun), and the lug nuts.
Oh....EVERYTHING on the exhaust gets it.
