Back Yard Solution
Nyghtshayd
I have some OEM motor mounts that I need to put in Nyghtshayd.
Does anyone know a way to replace these since I do not have an engine lift?
Thank you.
95blklsc
Or if you can brace from the top with some chains you could lower the cross member.
Do this ^^^ I would NOT want to try to change those without the subframe lowered at least 5 or 6 inches. When I changed mine I took the subframe completely out....
Nyghtshayd
Or, I could chicken out and send it to my backup mechanic ( ^,^)
I like that tool though, DLF, I'll keep that in mind.
Nyghtshayd
Why, YES, that would work too!
Good call Roadboss! :wave022:
I get how to hold the engine up but I don't get how to lift it with the 2 x 4's.
DLF
You don't have to lift the engine, just hold it in place while you lower the K-Member.
If you're going to try the '2x4' method, I'd strongly suggest either a 4x4 or at least two 2x4's on edge.
beerdog
harbor freight sells one for 60$. I have a HF right by my house and checked it out. It was actually pretty well built. I also used soem Unistrut once. It held fine,but it did bend a little.
If you go get the one at HF, don't forget to print a 20% off coupon from their web site.....
I did mine with the K member out when I was installing headers....killed two (or three) projects at once.
Without pulling or dropping the member, its a PITA. Also...don't disconnect the suspension when you do it, the k member will just hang there...less work.
